A problem has developed on my trusty old 205 with the indicators. The drivers side front and side repeater indicators are not working, only the rear, which flashes at double speed. Indicating left is fine.
All the fuses are ok, as are the bulbs, and I'm not sure what is most likely to be the problem.
Is this something that could be caused by the switch (or whatever it is called, the box that makes the clicking noise) that controls the flashing of the indicators going wrong and needing replacing, or is it more likely to be a wiring problem??
Any ideas appreciated!
