http://www.dvdcompare.net/peugeotfault.php
THE PEUGEOT 206 FATAL FAULT
ARE PEUGEOT WAITING FOR SOMEONE TO DIE UNTIL THEY TAKE ACTION?
In short, there have been instances where people have been driving their Peugeot 206 and have experienced a potentially life threatening problem which Peugeot are unable to resolve. The problem can be apparent in ALL models of Peugeot 206, no matter the age, engine size, condition or model.
The problem is simple: you can be driving along at any speed, in any gear and all of a sudden the whole car loses complete power. Every single warning light on the dashboard comes on and the car starts to lose speed at an alarming rate. Because the car has no power this means no power steering (which makes it much harder to steer) and the brakes go hard (which means it takes much longer to brake but when you're doing 70mph this isn't much help). Therefore if this happens in the fast lane of a motorway, there is a high chance you will be killed.
There is NO WARNING when this problem will happen. It comes completely out of the blue which makes it even more dangerous. If you own a Peugeot 206 and haven't had the problem yet, DO NOT THINK YOU WON'T. My car in particular was over 3 years old before the problem occurred. In fact, this is the reason Peugeot first gave for the problem - i.e. it only affects cars older than 3 years. This has since been proven to be false and can affect cars as new as 3 WEEKS!
All modern cars have an Electronic Control Unit (ECU). This is the "brain" of the car and is similar to a black box found within aeroplanes. If a fault occurs with the car, it should be registered on the ECU. You then simply take your car into your local official Peugeot dealership, they will hook your car's ECU up to their diagnostics machine and that will then tell them where the fault is and how it can be fixed. Except it doesn't. EVERY SINGLE reported engine cut out problem has NEVER registered on ANY ECU. This is where the main problem lies. Peugeot are unable to recreate the problem, there is no record of it on the ECU which basically means Peugeot do not know how to solve it.
So what happens if you experience the problem? Well, if your car is still within warranty, take it down to your local official Peugeot dealership and they will carry out any repairs free of charge. However, the repairs are POINTLESS. Peugeot don't know what the problem is so just try and replace things they "think" will solve it. They will do this even when your car is out of warranty which means you will be paying for repairs YOU DO NOT NEED. So far, the following items have been repaired/replaced on people's Peugeot 206's who have experienced the problem:
New ECU - cost between £600 and £1,000
ECU upgrade (where they upgrade the car's software)
New coil pack
New MAP sensor
New terminal connectors
New spark plugs
New sensors on the air intake
New fuel injector
New fuel injector wiring loom
The list goes on and on and on. Some of the above items fix the problem for a few days/weeks/months but eventually the problem WILL return. Remember because this fault does not show up on the ECU, it will also not show up on an MOT test which means if you're buying a second hand Peugeot 206 which has a clean MOT BE WARNED!
My Dad bought his Peugeot 1.4 LX car in 1999 (T reg) and gave it to me in 2002. I used it for about a year and I had no problems. Then the engine cut out problem began and kept happening. In the end I was told by the David Kerr dealership in Chelmsford, Essex (official Peugeot dealership) I would need a new ECU. Because the car was out of warranty, this would cost me £700. I begrudingly paid it and the problem went away. Well so I thought...
The problem conveniently returned a few days after the 1 year warranty on the ECU expired. It cut out whilst I was in the fast lane of the motorway. Luckily the road wasn't very busy and I managed to wrestle the steering wheel over to the left and get into the hard shoulder. So basically I crossed 3 lanes of traffic with no power, no steering control and no brakes plus at the same time losing speed rapidly.
I took it back to David Kerr who upgraded the ECU software. The problem went away for a couple of months and then returned. I returned to David Kerr at least 4 more times over the next 2 years and had more software upgrades, a new coil pack and other pointless repairs too numerous to mention. Each time I had to fork out between £40 and £100.
In early March of this year (2006), the car cut out again and refused to re-start. I called The AA out and they said "the car has a serious electrical fault and is too dangerous to be fixed by the roadside". I was then towed to David Kerr where I left the car and refused to take it back. You can read what happened next here.
Although this problem has received lots of publicity both online, on TV and in the press, Peugeot are still being extremely complacent and are not doing ANYTHING to rectify the problem (they may well be trying to solve the problem behind the scenes but from a customer point of view it just isn't good enough).
If you own a Peugeot 206 and have experienced this problem, please sign the online petition here (this petition is located on another website and is not connected to dontbuypeugeot.com). It is the only way Peugeot will listen.
Peugeot do NOT seem to care about their customers. The way they have handled this whole situation proves this. From Head Office down to dealership level (who to be fair are only acting on what they are told by Peugeot Head Office), they really couldn't care less. Remember, the Peugeot 206 recently came 99th out of 100 in a poll of driver satisfaction carried out by AutoExpress magazine. Do not buy a Peugeot 206.
The Drive of Your Life? More like The Drive That Could End Your Life.
