- 25 Mar 2004
- Fareham
Hi all,
At work I am working on a website which currently pulls data out of CSV's and displays in tables via ASP.NET C# code and Response.Write(), the CSV files are updated via scheduled tasks/scripts that run on the webserver.
Generally works OK but one of the CSV files contains 59000 records and as you can imagine dynamically writing a table using this method can take a bit of time, and doesn't handle that many records well at all.
I was considering feeding the data into a SQL table and using this instead, i'd imagine it would be quicker, what is the best way to achieve this taking speed as the main factor?
Some caveats:
Bit of a tall order really but not sure where to start, so would welcome some direction. I'm no pro at scripting in ASP.NET but I can take examples and figure them out/build up my knowledge as I go.
Thanks!
Some caveats:
- Columns need to be sortable and uses various field types such as text, numbers, dates.
- Data needs to be filterable, i.e. users can enter a value to search for in the fields and I can check if the row matches the filter before writing it out.
- On some columns, I would like it to check some thresholds and then display a different image depending if the threshold is good (green), warning (yellow) or bad (red) after the data in the table cell.
- Would be great if I could dynamically pick which fields to display, or otherwise deselect columns and then refresh the data easily.
Thanks!
