- 15 Dec 2011
Hi All,
I have a garage around 15feet from my house and there is ducting already in place that holds an armoured power cable which takes power from house to garage distribution board.
I have a need to put 3 cat6 cables into garage for CCTV and a WifiAP which I have been trying to do with the Armoured power cable in place - limited success as I think the new cable is going over and under the existing cable somewhere when I am pulling it through creating an unwinnable tug of war.
The ducting is more than wide enough for the cables to fit.
Today I gave it another go and yet again ended up with an unmovable cable after so many pulls.
I was thinking today - I could disconnect the garage power feed from the house and pull back through ducting....then attach cat6 cables to it and reefed it through as one entity avoiding the issue I think I am facing currently.
Has anyone does this before ie removed a cable from ducting and put back in?
My main concern is that on removing the armoured I am unable to put it back in and facing digging drive up as I assume the cable was put in before house was built.
I have a little slack on each end of the armoured and it seems to move back and forward with ease so a pull through should be easy enough.
I can attach some spare cat6 to one end when I am pulling through so I can pull it back without needing to put my cable rods down again.
Appreciate any thoughts/experiences.
Cheers
Cheers
