- 15 Dec 2011
Hi Everyone,
Looking for some old-school troubleshooting advice...
Set a pc up for someone - HP Workstation type - every thing fine for first few weeks, then started getting weird issue where pc after being turned on would cycle reboot without showing anything on screen ie really quickly, power light on front would flash red and you would get 6 cmos beeps each time.
Then MB would boot saying memory (RAM) had changed - had 6GB in it, would sometimes show 3,4 or 2 etc.
RAM was from another machine that was working fine so presumed MB issue so got another HP workstation and used RAM in that and setup - without an issue, ran for days at mines.
Took system to friends house, plugged in, all fine.
Plugged his USB HD in and system wouldn't boot.....then after few reboots - quick boot/mem message appeared on screen.
So simply - does it look like faulty memory or could it be something more complex?
Everything is different apart from the memory but the memory worked/works fine in another system.
Trying to hunt down the particular PC model on HP website to see what 6 beeps mean.
Any advice appreciated.
Also - Forgot to add - I removed one of the RAM chips and it booted fine...but then 2 days later started doing it again, with the RAM stick I removed still out of it.
