Pulling to left under hard braking
4 Sep 2005
Whitwood, West Yorks
The car heaves to the left under hard braking, so I am guessing the right brake isnt working properly - is this likely to be a simple fix or an expensive one?
I dont mind getting my hands dirty if its DIYable.
assuming it is a stuck caliper, how would one unstick it? And what causes it in the first place?
What car is it? If the caliper is stuck then it will probably need rebuilding. Not impossible to DIY but there are many places out there that will simply sell you a refurb on an exchange basis or rebuild it for you if you can wait. In any eventuality you will probably have the bleed the brakes which is not always a simple process.
I've had the pulling to one side under braking before, caused by a split CV boot which covered one side in oil/grease.
Worth having a look before dismantling you brakes :)
I've had this and it was worn wishbone bushes - causing the weight to shift unevenly under braking. I'd put my money on something like that rather than a stuck caliper
Have you actually looked at your brakes cause thats the best thing to do first as it maybe a number of things.
Well they look fine to me, but then again im not a mechanic.
My first thought was suspension related, but a few people have suggested stuck caliper over that
I'm having similar problems, a mechanic has said that it could be a sticking caliper. I'm going to get them to have a look at it when it goes in for it's wheel bearing replaced again.
There are a few things it could be, I had very similar thing on one of my cars. Turned out it was a collapsed flexi hose on the front.
Pretty simple fix, but it would be for me being in the trade lol.
