- 30 Mar 2007
- Essex
Guys I am speccing up my water Kit and need to find a pump
So far I have
Dtek Fusion CPU block with nozzle kit
Thermochill P120.3
3x Yateloonfans D12SM
Danger den Double 5.25 bay ressy
Now all the above have half in fittings for hose connections and the pump I am looking at does not list fittings :
Here it is
Laing DDC 12V ULTRA Pump & Plexitop
Dimensions: (WxLxH) 62x62x38mm (without connections)
Motor construction type: electronically commuted ball-motor
Working voltage: 12 V DC Voltage
Admissible voltage area: 6 to 13.2 V
Delivery height: at 12V: 4,7m
Max. delivery rate: 600L/hour
Delivery media: water, water-/glycol compounds
Max. system temperature: 60° C
Medium-affecting parts: stainless steel 1.4571, PPS-GF40, EPDM O-sealing rings, alumina, hard carbon
Connections: 2x 1/4" hose connection
So I have 2 questions for you guys
1.Can i get some 1/2 inch connections for this ? Also is this pump any good ?
2. I have small jubilee clips to secure the hose connections but are they the best way ...I quite like the screw down connectors that tighten up the hose as you screw it down .
I am more than happy to change the whole fittment of the barbd and hoses if 1/2 tubing is no good ?
So far I have
Thermochill P120.3
Here it is
