Pump before or after reservoir in loop?
5 Apr 2008
I have a single bay reservoir, and a pump at the bottom of the case, should i have it so the reservoir is before the pump or the pump before the reservoir,
ie.
either
res - pump - waterblock - rad - res
or
pump - res - waterblock - rad - pump
Loop order does not matter at all. It is EASIER to have the res before the pump as it helps bleeding the loop but once all the air is out of the loop then the res can go anywhere.
