I've had a new system build with an Asus Dark Hero motherboard and an EK D5 pump for a custom loop. 2 420mm rads cooling just a CPU at this stage (5950X), so kinda overkill surface area lol.
When I first got the rig they had set the pump to run at 100% constantly which was very loud at 4.8K rpm and totally unnecessary I think. Thing is when I set it to PWM with a temp curve in BIOS, it appears to change speed randomly even when the CPU is not really doing anything... this pump makes a fluttering sound whenever it changes speed so I want to avoid this if possible.
What are the temp curves others are using with a D5 and/or what is the best way to avoid frequent speed changes? Do I have something set incorrectly in BIOS? Thanks in advance.
