Jaap74 said:I'm always paranoid that somebody will hear me using my pump![]()
Arcane said:I use the Petra Tech Gel Stuff.
I have a DDC with an alphacool top,w3bbo said:What pump? If its a D5 variant then use foam/gel pads. If its a DDC with an alphacool top then you can buy a dampening kit (£5) that allows you to mount it in a HD bay and this also cuts out most of what little vibration there is.
