Pump died
31 Aug 2009
Well my pump gave up the ghost late this morning so am now in need of a new one. My rig is due a flush out spring next year so am now planning bit of a refresh new tubing new fluid going with a red one on this now. Now pumps. I am now thinking I want to go for one that fits on the bottom of a tube res. There is this guy in Australia who does singularity computers and he uses a bits power res and d5 pump combo but with upgraded bits to cover the pump and stuff but I just can not find all the bits for this. My other option in my head is go for thermaltake new combo units.
Advise welcome.
There's the D5 and XSPC Photon combos. The Photons are glass reservoirs so don't stain plus they look really nice too.
My basket at Overclockers UK:
There is also the Monsoon MMRS systems which can take a D5 pump and you can basically make them look however you like. There is even a configurator here although some parts are out of stock at the moment.
The Aquacomputer aqualis D5 is designed to fit straight onto a D5 pump and is also a glass res.
I believe there is also a version of EK's Xres tube reservoirs with a D5 pump.
i liked the look of my 270 but its a pig to fill.
super, super quiet though. Ran on 5 for best part of 2 years without any vibration or pump noise.
Tell me about it. I have a stand alone 270 and ended up modding it. I took the disc out of the top and it fills easily now. I also fitted one of these to the inlet so that when filling/bleeding the outlet doesn't simply suck the air back into the loop.
