- 29 Feb 2012
- London
Hi guys
I'm using the gigabyte z390 aorus master mobo.
I'm using the barrowch 17w PWM 960LPH pump.
Its plugged into SYS_Fan5 header 4 pin as instructed in the mobo manual.
I've set curves for the fans and pump in the bios.
So when I'm on the desktop the pump sits at 1860rpm, loading origin the pump starts to kick in and when in game (apex) the pump is going along at 3600rpm which is to quick.
Before It was set to 2300rpm at all times.
I have no idea what's happened?
It seems that when the cpu or gpu are unload the pump kicks into overdrive.
Is the pump defected?
The minus button on the pump doesn't seem to work to bring down the speed.
The pump is connected to a barrow distribution panel.
Thanks
Thanks
