Pump Noise
28 Feb 2011
Norwich
Hey guys i have a newish h100i v2 and today a kind of loudish noise has started coming from the block that sits on the cpu, which im guessing is the pump?
Its louder than the fans and sounds like a kind of grinding/rattling noise.
Any ideas? I got it from maplin on offer, if i rma it to them under warranty im totally getting the model above from ocuk
Hi, have you moved your PC recently or tipped it over to do something to it.
If so put your pump on maximum rpm and tip the case up slightly the way the water circulates as you might have trapped air in the pump.
If this does not work the pump could be on its way out.
I've tried and it comes and goes. I've changed the pump to performance and quiet in link but it doesn't change much, still grinding away but occasionally it stops. Do you think it will be accepted as a fault?
