I'm new to watercooling and have got a Swiftech mcp355 Laing DDC pump.
I'm coulpling it with a EK DDC res 140.
After removing the original pumptop from the pump I've joined it with the res keeping the same orientation i.e. the inlet and outlet on the same face as before. However as the wires from the pump now evit on the wrong side for my build is it possible to take it apart and rotate it 180 degrees or even 90 degrees. Essentially is the pump unidirectional in it's output or can the new pumptop/res be mounted on it in any orientation?
