Pump producing hardly any power?!
11 Sep 2014
Suffolk, England
PROBLEM SOLVED! Was just a lack of water in the system, it's filling much quicker now as I type this. Air bubbles too. Thanks everyone for your input :)
So, I've just started to fill my first loop. I fill the res, which feeds down into the pump & goes back up to the cpu block. The pump is running, I hear it, but it isn't pumping the water past the cpu block section. It struggled to get the water up there but got there just about with a few tilts of the case. Is this normal for a first fill? or should the pump push the water through much faster?
I have the molex from the pump connected to the led strip molex's (enthoo primo). Is this the reason?
Is the 3 or 4 pin connector connected? It'll be slow if its PWM and its not connected (4pin )
It's not connected, but when it is it won't pump anything at all because the mobo has no power. The 24pin is on the paperclip treatment & the 8pin isn't connected. Should I connect the 8pin to the psu?
I would definatly plug the pump straight into the psu via molex rather than piggybacking another molex connection
What are the parts in your loop?You havent let your pump run dry have you?
First and foremost which pump are you using?
EK D5 with pwm control
I haven't got the right cables to connect it straight to the psu. It has a male molex connector & I only have a male to pci-e connector :(
It's only a cpu loop. It's not running dry, I can hear the air bubbles in the pump right now.
Im fairly sure even without power all the pump needs is that circuit completed. If you plug it in, it'll work. I've the same pump and without the 4 pin connected its snails pace, once plugged in its super fast.
After a fairly quick leak test. Like, maybe an hour or two, I've plugged everything back in & turned it on. Got the 4 pin plugged into the cpu_opt header & am able to control the pump via the Asus thermal radar software. Turned the 'cpu fan speed' up to max to see what it was affecting, the pump nearly took off aha! Bubbles storming through the loop & out. That's one way to get rid of them in a hurry aha! Got it sitting at 50% now for a bit & it's silent :)
Ironicly, this thread helped me also. I was unable to reduce the speed on mine till I put it in the CPU_header and now its finally not running full speed lol. Even reduced temps by 3-6c on idle.
Oh sweet! Glad I could help aha :) I just remember someone saying that the cpu header on most/all modern motherboards have pwm control.
