Hi guys finally found a full cover block for my gpu so, full loop is a go!!
I have picked the Alphacool Eisbecher Helix 250mm reservoir and I am unsure which D5 set up will work with it? a lot of pump combos i have seen, the res seems to screw into the pump but this one doesnt look to do do, Would the only way to use this is res - tubing - pump?? if so can someone link me to the one i would need on overlockers shop?
Many Thanks
Many Thanks
