- 4 Jun 2010
So the pump I am getting is:
But the pump top i have found is:
Alphacool HF 1/4" D5 TOP - Black Acetal
Now this pump says it works with these pumps VPP655/TPP644/MCP655,
Will it fit? Also if I need to change the pump top can I just use the O-ring that hasnt been used off the old pump top? As i do not belive I get a new one with the top.
Thanks
Freddie
Laing D5 (Alphacool VPP655-T12) Variable Speed 12V Pump for 1/2" ID Tube : VPP655-T12
Thanks
Freddie
