- 17 Jan 2006
Hi
I installed a couple of mini patch panels at the weekend and last night set about running wires into them and connecting them. I used the cheapo punchdown tool I picked up from ebay a couple of years ago and found that it really didn't do the job, the metal pusher bit seems a bit too fat to fit into the plastic slot so the wires don't get pushed down and the cutter is fairly well useless.
This morning I've picked upa slightly more expensive one from screwfix but to be honest it looks exactly the same and I'm not convinced it'll be any better.
Now, having read the reviews of this tool they all seem positive so I'm wondering if I'm just not using it properly (not that it seems like there's a lot to it), anyone got any tips/advice on using them?
