Having just rode home after work, only to be told a little way away from home that my tire was down when I stopped at a toll booth, then getting home, trying to test it and having a reading of 0 psi I realised I have a puncture
What are my options, as you can see by the picture, the puncture is in centre of tyre, did a quick search and came up with this;
http://www.sportsbikeshop.co.uk/motorcycle_parts/content_prod/2689
Worth a punt? Or better to stump up est. £65 for a new tyre, would like to replace like for like, but cant find any prices for them at the minute, the tyre has currently done 4.5k miles. I'm probably going to have to use that motrax stuff anyway just so I can get the bike out to get it repaired.
Cheers
Cheers
