26 Jun 2015 at 01:25 #1 maklabouhlel maklabouhlel Associate Joined 26 Nov 2009 Posts 1,232 How do you take the transparent film off the glued puncture patch (assuming it has one) without lifting it from the tube?
26 Jun 2015 at 09:57 #2 Supercow Supercow Soldato Joined 30 Aug 2003 Posts 14,225 Location Straya I found peanut butter just around the edges works really well
26 Jun 2015 at 10:20 #3 Amps Amps Soldato Joined 23 Mar 2003 Posts 2,651 Location Scotland Can you not just leave it in place?
26 Jun 2015 at 10:20 #4 FrenchTart FrenchTart Man of Honour Joined 16 May 2005 Posts 31,297 Location Manchester I remove the film before applying the patch. Alternatively, just let it set longer.
