Punto red key
18 Oct 2002
Maidenhead
Hi all,
I cant find my keys at the moment. Ive got the red key for my punto, is it just a normal key so I can use it until I come across my house keys?
Thanks
Paul
it's 'ok' to use for a bit, it will put the ECU into programming mode at some point though.
should be fine. think you can get a new key cut from that key as i think it is the master. just make sure you dont lose it
