Purchasing 4 sticks of 8gb.
16 Jun 2006
Bournemouth, Dorset
So im contemplating buying some new ram, 4x8gb of Dom plats, is there any good reason to buy them in a pack of 4? As it works out cheaper to buy 2 packs of 2 it seems.
So im contemplating buying some new ram, 4x8gb of Dom plats, is there any good reason to buy them in a pack of 4? As it works out cheaper to 2 packs of 2 it seems.
If it's a lot cheaper then I've bought the same many times, including my current sets and not had any issues, but if it's only a small amount I would consider buying a 4 pack to remove the small chance of any potential issues?
