Purple Nova
10 Apr 2015
Hungerford, UK, Earth
I had an old Bitfenix Nova case which the front facia had started to fade and yellow. I have been putting a PC together for GF Daughter, and her favourite colour is purple. so bought a couple of cans of plastikote spray and just sprayed the front facia. Luckily the side vents came off easily and the whole power button assembly comes off in one piece. didnt bother putting the logo back on
if you look at the front foot in first pic, thats what colour the front panel had gone to, maybe i should have sprayed the feet as well. or a coat of white. never mind.. I have added RGB lighting set to purple in the case as well. I will add a pic of the complete setup once installed.
