- 29 Dec 2009
- Germany
When using a D5 Vario or variant (such as a MCP655), should you have the pump be pushing water through the loop (directly after the reservoir), or pulling water through the loop (directly before the reservoir).
Reason I'm asking is because I read elsewhere that the D5 pulls better than it pushes, and should be mounted directly before the reservoir.
