I would have thought you should match fans on push pull or they'll be fighting against each other with mismatched flow rates
If you are going to mismatch them then no it doesnt really matter which way round you have them, one will be causing a blockage for the other
Speed is irrelevant, it is flow rate at that speed that is important
Try it with one fan, then both, see if you actually get any improvement
