- 21 May 2010
I recently purchased a Zalman performa cpu cooler for my 955 and it comes with clips to add a second fan. The fan I purchased for this second fan is an arctic cooling F12 and im only able to connect it to a 3 pin header on my mobo so the speed is constant at 1350rpm with an air flow rating of 57CFM. Its quiet enough so i dont mind having it run at full speed. The fan supplied with the heatsink however i am unaware of its air flow rating. Its speed varies from 900 to 2000rpm. what im wondering is would it be better to have the constant F12 as the push or pull fan or does it not really make much difference?
