Obviously one goes into the CPUFAN connection, where does the other one go and how do I make sure they stay at the same speed. I'm using a Noctua cooler and Gigabyte GA-EX58-UD3R motherboard.
I use a Y splitter, but this places more load on the motherboard and is not recommended. If you're using PWM fans, then this is ideal. Otherwise you could run both fans at 12V, or use a manual fan controller.
