Push/Pull Hyper 212 Evo
3 Sep 2012
P town
Hi all I have the hyper 212 evo cooler and CPU is phenom ii x6 1090t. So at the moment the cooler is in push configuration with the supplied fan. Soon I intentd to overclock my CPU so ideally want another one or two fans as the current one is quite loud, so then I can have push/pull configuration. Also I have enabled the fan setting in bios forgot the name but it reduces RPM of fan but still not happy with it :p So I was hoping someone could recommend me a quiet fan that has good airflow and static pressure?
Case is Casecom 6788 with front and side intake, outake is back and top. Had two fans on side as intake but had to remove one due to cooler :p
So yeah that's all I have to say for now, thanks
I have a 1090T on an ASUS 990X board. i use a thermalright TRUE extreme 120mm with two Akasa viper 120mm fans in push pull. I have them both running PWM and can hardly hear them for most of the time.
I have one apache exhaust fan and a Lian Li intake both 120mm and also running quiet. The apache runs off the same PWM splitter as the vipers. The Lian Li is undervolted to 7V.
I overclock to 4GHz and my CPU usually operates below 43C occasionally rising to 52C under load.
YOUR BASKET
1 x Akasa AK-CB002 PWM Fan Splitter Cable £3.59
Total : £5.87 (includes shipping : £1.90).
