Hi all,
I've currently got the h100 with stock fans setup to factory specs blowing air in over the rad (which I understand, cool air in from outside over the rad into the case fore more convection cooling).
However have 4 thermaltake cougar fans coming soon and am going to a push pull setup for hopefully a quieter cooler situation (thought I think the GPU's make more noise so this is probably a waste of money, but hey they look cool).
Now my questions are thus:
1.) anyone played around with the direction on this setup - Do you have your cooling blowing in or out? Did you see much temp difference?
I think I am going to keep it going in as there is a 120mm fan extracting out the back of the case right by it
2.) space for installation anyone managed to successfully drop this or another rad setup into a HAFX case and still have the top fans (200mm ones) in place?
Haven't had chance to try it but the motherboard power cable looks like it's going to be tight with just the new underside fans let alone if I drop the whole top and rad and new bottom fans inside the fram and have the 200mm ontop.
3.) Lastly if I were to fit the push pull inside the case with the 200mm ontop, any thoughts on making them the exhaust and turning the 120 rear fan around?
It's a cold garage conversion room, so other than the middle of summer air in here is closer to outside than rest of the house.
Thanks,
James.
Thanks,
James.
