Push/Pull Mix
14 Sep 2008
Peterborough
Wasn't sure whether to put this in water or regular cooling subsections since it could apply to either.. But anyway..
I've got H100 coming tomorrow with a bunch of Akasa Apache's. I was considering leaving the stock H100 fans on and adding 2 Apache's, and having 2 Apaches as case intake fans (already have 3 stock case fans in my Cosmos S). I'm going to assume the Apache's will be better than the stock corsair fans.
So the question is, Would you put the more powerful fans as Push, or Pull? Will it make any difference? Will it gimp the airflow? Am I better off using all 4 Apaches on the rad and using the Corsairs as case fans?
