Push/Pull on radiators question
20 Oct 2007
This is probably a really stupid question, but when using push/pull wouldn't it be better (or at least, no worse) to have a high static pressure fan doing the pushing, and a high airflow fan doing the "pulling". That way the air is getting pushed through the rad using static pressure and then blown away as quickly as possible..
Using such a setup, would there be any advantages in having two static pressure fans?
