I would use two equal fans, if you push 89cfm into a space which is being exhausted at 68cfm you will have an excess pressure in between the fans. Similarly the 89cfm exhaust fan will pull air faster than the 68cfm can push it, tending towards a zone of low pressure air in the middle. This will not actually occur as air will be pulled in from the sides.
The other problem may be noise as the two inequal rpm will interact and you may end up with a pulsation going up and down in volume.
