I have a megahalem with 2 fans in push pull on it and want to control them both on the same channel with a Zalman fan controller (that one). Now, the controller can handle 7w per channel and the Yates are rated at 3.6, meaning I'm 0.2w over the controllers limit.
First question is, what problems could this cause? Could it break the controller or is 0.2w within "safe" tolerances?
Secondly, as a compromise, if I was to run one fan off the controller and one off a motherboard header (they aren't PWM fans so it will be running at 100% all the time), which fan is better to have running 100% the push or the pull? Or will it not make any difference?
Sorry for the noobie questions, hope someone can help!
