Push pull with Fenrir?
2 Jan 2009
Lincolnshire coast
Any ideas how I can add an additional fan to my Titan fenrir?
The Fenrir only has grooves on one side so no easy way to add another fan in push pull config.
I'm mid mod right now, and have few ideas re how to do it, but none of them are very elegant, so thought i'd ask the benefit of the forums wisdom
I've read about people using cable ties for it. How about 2 rubberbands? Around the cooler so that it holds both fans at the same time
Cable ties would be a good job, with rubber bands youd have to replace them pretty often as theyll perish and weaken pretty quickly and the fan could drop into the case.
Thanks for the advice, with the cable ties do you simply wrap them round the whole shooting match or is there a little more finesse to it than that?
I've heard it can be done with velcro but not entirely sure how that would work???
Ideas???
