Push/Pull worth it?
29 Dec 2009
I currently have the Corsair H100 (no noise!) and planning to get either the Corsair 650D or Corsair 800D.
Siding towards the 650D due to it being £100 cheaper nearly, but can't fit push/pull in it.
So I'm left wondering is there any real difference between running just two fans on the bottom pushing the air through rad and having push/pull config?
my 650d push pull
800D push pull
Push/pull on the H100 made no real difference
I run push/pull on my Antec 620 thing, can't say using one fan made a noticeable difference to temps, but I had a spare fan to use to left it on! A single fan will be absolutely fine :)
I don't think its really worth it if you have to buy extra fans for it. I think its better just to get a good high quality fan like a gentle typhoon. Perhaps it is more worth it for the extra thick radiators.
push pull is pretty pointless. I have ran rad fans in push, pull and push/Pull and found that having them in push or pull works the best with push/Pull making no difference to temps
+1 - To get good CPU temps its a combination of good air flow through your case and CPU cooler[air or water] by having the right fans to do the job.
no push pull is never worth it imo, you're better to go for quieter fans and sacrifice a couple of degrees, than to go for push pull and have it 9 times out of ten being noticeably louder
