put my new build together, minor issues, some help needed
21 Dec 2010
hi all,
got some great help on the forum so thanks for that,
i finally put my pc together, but now i have problem installing my graphics card drivers
i am running windows 7 64 bit and my gfx card is a msi 460 gtx hawk talon attack
my driver enters the install and it has been going at it for an hour, at 75% and doesnt seem to be moving OR very slowly
is this normal or is it a problem with something?
thanks !
mapi
hey, if your using the disk supplied with the card bin it and get the latest ones off the msi or nvidea website. if using the downloaded ones have you tried restarting the installer or pc itself? and made sure there is no programs in the background that could be affecting the install
thanks guys, i got the card drivers installed now.
i installed msi afterburner and some other programs, but none program will work
for example if i open msi afterburner i get
Some of MSI Afterburner components are expired missing or corrupted!
if i launch darkfall lobby updater i get: Invalid command line
is something mess up? or what does this mean that a lot of apps are broken
