I'm an avid DIYer and after 2 years or so of doing 2 bathrooms and one room I'm becoming quite the dab hand at it all.
However, I'm at the point where I need to put a 150mm wide hole in an external wall for the extractor hood (currently no external vent in the room) and it's simply something I've never done before.
It's a victorian house so the walls are stone built and roughly 530mm thick.
I figure the two options are either a diamond core bit, or stitch drilling with a regular masonry bits.
I don't have an SDS drill, or any appropriate bits for either option.
Looking at the costs of hiring a diamond core bit (which seem to be a max length of about 320mm) with associated drill seems like it will cost me in the region of £120 given that I'll need to do it at a weekend and likely need it for at least 2 days - because literally everything I do always takes at least double the amount of time I predict... which means I'll probably take 4 days... but then if I predict 4 days I can absolutely guarantee it will take 8 days...
Aaaaaanyway...
Other option, as I see it, is I could probably make long term use of a regular SDS drill, and combined with one or two bits would likely only cost me the same as hiring something specialist.
As I see it, the biggest challenge with hiring diamond coring bits is lining up both holes as I'll need to drill from both sides - obviously a pilot hole will help mitigate this though, but that means buying/renting drill bits for this purpose as well.
With stitching (with a newly purchased SDS drill and bits) it's keeping everything aligned and level as I put 10 or so holes through the wall...
Anyone got any advice or experience with either/both options? Any pointers, recommendations for drills/bits or alternative methods?
Thanks in advance.
Aaaaaanyway...
Thanks in advance.
