Putting a graphic card in my system
11 Sep 2008
Hi guys. First of all i wanna say thank you for the help i have had recently with a few threads, it is appreciated.
Now, i have ordered an Asus 4850 to replace my 9600 GT (It comes tommorow) But i have never put a PC together or done anything hardware wise. Now is it difficult to swap the cards? I am pretty much asking on how to do it, any tips or anything since i am not experienced with this. I want to start learning now :)
Thanks guys.
Uninstall the current drivers, then use driver cleaner to totally get rid of them.
open the case up and swap the current card for the new one, making sure you attach the cables from the PSU if needed. boot up the computer and install the new drivers for the new card.
Uninstall the Nvidia drivers in control Panel,
Shut down your pc remove the old card, install the new ATI 4850 connect the power cable, restart windows and proberly show new hardware found I tend to ignor this, go to the ATI website dowmload the latest drivers, install and enjoy.
Make sure that you touch a radiator or something to earth yourself before you touch any of the electronics. Its a long shot that static electricity will cause any damage but better safe than sorry.
