Permabanned
- 10 Dec 2008
- London
Hi chaps,
I have a watercooled system. Due to a (now fixed) leak the system needs a complete refill of di-ionised water.
My question is this .. after I have added as much liquid as will fit into the reservoir (via the fillport) .. do I screw the cap on before turning the PC on for the first time?
Some people say 'Yes, the system needs to be pressurised to work so you have to ALWAYS have the cap screwed on when the pump is working'. NEVER run it with the lid not screwed up'
Others say 'No, leave it off for a while so all the air that currently in the tubes is pushed round the system, then out where the cap was (!!) (then you should be able to add some more liquid THEN finally screw the cap back on).
Any help vastly appreciated. I've fixed the leak -- but don't know how to refill the system safely....?
