- 16 Nov 2003
- On the pale blue dot
So the other day I broke down on the M4 when the car overheated because the water tank was empty. I had filled it up a few days beforehand because it had its MOT. After a top up from the AA to get back home, Mr AA noted that when I was pulling away white smoke was coming out of the exhaust and then he used what looked like an ph test strip in the water tank which came out green, to which he said there was petrol gases in the water and the gasket had most likely gone.
So I took it down to a local garage and they said that there was nothing wrong with it. They pressure tested it and proved there was no leak, said the oil was the right colour with no sign of water in it and there was no sign of white smoke coming out of the exhaust.
Since then I've taken it for a spin with someone following and the exhaust seems fine, the temperatures remain steady and the car drives well. The only new problem which occurred a couple of days before I broke down is that the car is idling a bit off, which I put down to the engine needing a servicing. Problem is though, in the 9 mile drive to work the water went from max to half way between max and min. I've let it cool and topped it up and it stays steady, there's no water dripping onto the drive and no water coming out of the exhaust. Another drive- another half of water gone.
Where is the water going?
