My PSU doesn't have the 6-Pin PCI-E graphics connector, it's a cheapy one. I got an adaptor with my X1950 pro, It has two of the usual 4-pin connectors on it, this then converts into a single 6-pin.
Anway, I connected just one of these 4-pin connectors up, not knowing you were supposed to connect up two. And the result? the card runs fine! Even benches as it should in 3d mark. So why do they come with two connectors, are you supposed to connect them both up?!
If you even thought about doing it whilst it was still on!
Came up with a windows encountered a serious problem window
