PWM Fan, 3 Way Splitter
1 Mar 2004
Kent, UK.
I want to disconnect the fans from my Asus Ryujin AIO and run them from the motherboard, does anyone know of a good 3 way splitter? The only ones I can find are either to short at 10cm, or the have a molex connector on them like the EK one on OCUK?
Akasa have a 5-way with SATA power connection, but be careful with wires breaking off of connectors. They run too many into too small a space with no stress relief making them prone to metal stress fatigue and breaking off.
Also, a single motherboard fan header is nearly always capable of powering 2 fans, but be careful when using 3 or more fans on the same header.
If you're unable to find the SATA powered 5-way splitter cable, then there are molex/SATA adapters that you can purchase. But at that point, maybe it's more worthwhile just getting a PWM hub such as this:
XSPC 8 Way PWM Splitter Hub Sata Powered - Black V2= £8.99
