I have this Mobo Bios Vers 0701 (might have to update this.....)
I am using the H80i with 2 new SP120 PWM fans attaches to the mobo headers. I dont want to install Corsair Link as I don't like tray programs when I can just use the BIOS settings... However asus qfan control in BIOS seems to be a little ineffective... I have an older Asus mobo where when I select turbo mode my fans spin up to full under.... On the Maximum V when I select turbo they never seem to go past c. 60% which produces an annoying whine but little additional cooling... The same seemed to happen when I tried manual control - indeed the only way to get them to run at 100% was to disable fan control.
Anyone got any ideas? My 2 SP120 fans are set as push/pull intakes with the push fan attached to the cha2 header & the pull fan attached to the CPUfan header - the H80i puimp is only 3 pin so put this on the CPUopt header.
