- 28 Oct 2012
- Camberley, Surrey
Hi All,
I bought a Corsair 5000D case to replace my ageing NZXT Phantom 410. In my old case all the fans were plugged into extenders that hooked up to a control board, that was controlled by a manual switch on the top panel. Slide the switch down and the fans spin slower, slide it up and they go full pelt.
With the new case, it comes with a PAWM board that needs power, and then connects to the motherboard. No bother, I've hooked it up to a SATA power connection and SYSFAN_1 on my motherboard (a Gigabyte Z97 Gaming 7).
The problem is, how do I now control the fan speed? They're all running full pelt and I can't figure out how to slow them down. I don't know whether I need Corsair software, I've tried the Gigabyte "System Information Viewer" and that doesn't seem to have sensed the presence of the fan control board. Also all my fans are 3 pin, but the control board male pins are 4-pin, if that means anything?
