I'm in the process of changing my 2 x 360mm Radiators for 2 x 480mm. But have come up against a problem. (Case Phanteks Ethroo Primo)
I currently run my radiators 6x120mm (4 pin) PWM fans off my motherboard (Asus RVE) 4 pin fan headers. Now I'm left with 1 spare, as the CPU_OPT is used for a Phanteks PWM controller for 5 X 140mm case fans.
So this is where hopefully you guys/gals come in. Can somebody point me into the right direction for a PWM (4 Pin) fan controller that can power 8 x 120mm fans.
Thanks
Thanks
what case are you running?
