- 5 May 2004
hi guys its been a very very very long time since i built pcs lol the last one i did for myself was a amd 939 i believe
anyways to cut to the chase my son now has a gaming pc which i specced and my cousin built kindly.
but i think we need to put a couple of extra fans in with the summer coming as the temps are ok but could do with a little more air flowing through for the gpu which read 73-78 when gaming.
specs are
phanteks pro m acrylic case
gigabyte z170a gaming 3 mobo
16 gig kingston fury x memory
gigabyte g1 gaming 980ti windforce gpu
i5 skylake 6600k cpu with Cooler Master Hyper 212 Evo CPU Cooler
right my brother has 4 spare akasa 120mm pwm fans which i want to fit and the mobo which can be seen here http://www.gigabyte.com/products/product-page.aspx?pid=5497#ov has 3 sys fans which are 4 pin ones so im prosuming they support this pwm and i have been told i can put the fourth fan in the cpu opt header as long as its the rear fan ?
the three things i need your help on is
1) is the above ok and safe to do
2) how are the fans controlled ? auto ? setting in bios ?
3) my brother seems to think the fans will run at full speed and wont be controlled and therefore will be loud . why would this be ?
thanks guys sorry for long post but its best to give all info in one go
specs are
