PWM fans - Ticking noise? O.o
26 May 2009
To cut a long story short, I have a Corsair Carbide 500R case, under the roof is a XSPC EX240 rad and on the roof is a pair of fans. The fans I had been running were a Scythe Kaze Jyuni 500RPM Slipstream and a Noiseblocker Multiframe S-Series M12-S1. I had these spare (former case fans) when I put the rad in (originally intended for it to be passive) and decided to whack them on as they were silent. I recently decided to upgrade them to PWM ones and bump up my overclock (as the PWM would ensure the fans only got audible during gaming when I would have headphones on).
*However* I bought a pair of Akasa AK-FN059 120mm Ultra Quiet Venom Viper which although inaudiable at low speed from an airflow/motor point made an annoying ticking noise that I could not stand, so having read this was normal via the reviews I then purchased a pair of Noiseblocker BlackSilent Pro Fan PLPS fans and again silent but annoying ticking lol.
Is this a common thing with all PWM fans or just these ones? O.o
used a 3 pin adapter to connect one of the fans without the PWM wire and no ticking, however as it was running at the full 1500RPM the air movement was annoyingly audible, not sure if the ticking is a PWM thing or just something these two particular types of fans do at their lowest setting, /meh back to using the old quiet ones now.
