PWM Help Please
Permabanned
17 Sep 2014
I have a Phantek fan hub, 3 Phantek PWM fans and I am using a Asrock Extreme 6 Z97.
Basically, I cannot get it to work. I can get a single fan to work if I plug it directly into the CPU fan header, though. I've set it up to run at 50% speed and it runs at 50%.
The moment I route the fans through the fan header they all run on 100% irrespective of the BIOS settings (which work with a single fan). Can anyone help? Seems very odd to me - something to do with the PWM part of the hub?
