Hi - I had to turn my system on fully first time to bleed it as my D5 PWM pump would only run at 60% and wouldn't fill the system. Fortunately no leaks. About to add GPU block and do not want to leak test with MOBO powered up. My PSU has cables and sockets for connecting fans -
Question: if a connect the pump's PWM plug directly to one of these cables and the PSU will it run at 100%. Nervous to try it just in case something goes up in smoke.....
thanks.
thanks.
