Hello Peoples,
So i have just re-built my pc after getting a new case and im looking for some advice on keeping the system as quiet as possible. I stuck in the old case fans from my previous case - Enthoo Pro Mid Tower Case - so im using the 200mm one at the front and a 140mm as an exhaust.
They are both 3 pin fans and i think are only capable of being either on or off? if i set them to DC in the bios they just stop - is that because the temps in the case arent high enough to get them to kick in? and is there any danger in leaving them off?
I have the cpu watercooled and so there are 2 fans pushing air through the rad, so some air in the case is being shifted out.
So really im asking if having the fans on DC, meaning that they are off most the time is a bad thing or should i invest in some 4 pin fans that i can set to be on low? Cheers for any help.
